Need Wheel Help Asap!!!!
Old Feb 16, 2005 | 03:05 PM
03NJg35's Avatar
i have an opportunity to get a set of chrome 20s for my G, They are 245/35's on 20x8.5's up front and 275/30's out back on 20x9.5's. The tires are brand new Nitto NT555's...the offsets are +32 up front and +35 out back...before i go ahead and get these, does anyone anticipate any probs with rubbing or anything like that? i need some advice asap b.c i dont have much time to make this decision...thanks for any help!
Old Feb 16, 2005 | 07:52 PM
03NJg35's Avatar
anyone? anyone with advice?
Old Feb 16, 2005 | 08:07 PM
GXCLUSIV's Avatar
For Sedan should be o.k. For coupe Im not to sure. Offsets Ive seen for 19's or 20's are around +17 to +28et for coupes. +25 offset is the safest for coupes. The offset you have will not rub outer fender, but may rub inside against shocks/struts. Call your nearest Discount Tires for fitment Q's.
Old Feb 16, 2005 | 08:31 PM
03NJg35's Avatar
too late..lol..just bought them, i have a non brembro G and i was gonna buy the wheels on ebay from this guy but i found a private seller for alot cheaper and larger wheels, the one seller is a rim place and he said that offset and size would be ok so i'll take his word for it...
Old Feb 16, 2005 | 08:37 PM
Gsedan35's Avatar
Rear offset and tire size would not be ok for a sedan. 55mm offset's will work on the sedan and will not rub the shock or innner suspension with a 9.5" rim and 275's. Front would be ok, but 38mm/35mm is the optimal offset with that rim width in the front, again for the sedan.
Old Feb 16, 2005 | 09:05 PM
03NJg35's Avatar
im stupid...i never wrote that i have a coupe
Th611
Oct 27, 2015 03:48 PM
Ray Feta
Aug 20, 2015 08:46 PM
poker_lamina
Aug 14, 2015 12:57 AM
Pcruz
Aug 12, 2015 07:46 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
