17" OEM sedan wheel will fit over brembos?
Feb 16, 2005 | 04:31 PM
Does anyone know the 17" OEM sedan wheel will fit on a coupe and fit over brembos?
Here's the spec for the OEM wheel:
THE WHEEL SIZE IS 17" X 7.5 WITH A BOLT PATTERN OF 5-4.5. THEY ARE MOUNTED AND BALANCED ON 225/50/R17 OFFSET IS +45 mm.
Reply 0
Feb 16, 2005 | 05:09 PM
Offset is to high, you need like a +30 or less to fit.
Reply 0
