Rear wheel help
Old Feb 17, 2015 | 11:29 PM
rznballa's Avatar
Rear wheel help
I have an 04 coupe and i have the opportunity to purchase some Vossen cv2s for relatively cheap. The only problem is that the rears are 20x10.5 +45. Would i be able to run those in the rear with such a high offset? any help is appreciated, thanks
Old Feb 18, 2015 | 12:53 AM
Urbanengineer's Avatar
There are ~ 25.4 mm per inch, so for every inch you gain over stock width should evenly push the wheel 1" from stock 33mm offset.
Add +12mm for your wheels offset and you get +37.4mm.
Now go out to your car and see if it can take about an inch and a half of growth out towards the fender. Is it too much? Consider "rolling" the fender to get it to fit. Google before you ask what that is .
Hope this helps.
Old Feb 18, 2015 | 10:52 AM
Texasscout's Avatar
That's a Sedan off set, and a weird one at that.
Old Feb 18, 2015 | 02:01 PM
rznballa's Avatar
that all makes sense, thanks. I was planning on rolling my fenders anyway, but do you think it would clear the suspension?
rezendvous420
May 31, 2020 01:26 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
