What causes wobble?
Old Sep 29, 2015 | 09:45 AM
aaron3719's Avatar
What causes wobble?
Guys, what can cause a small wobble at low speed? I can feel the wobble going at 20 mph but it feels normal again at higher speed.
Old Sep 29, 2015 | 10:12 AM
KruZZe's Avatar
Its easy to eliminate wheel bearings if you jack your car up, and grab the wheel and push and pull the wheel to see if there is any play from side to side at the hub. if there is play, then the wheel bearing is your issue. i would read this article (http://customwheelsmarket.com/diwhvi2.html) as it has plenty of good information about diagnosing tire issues, and see if you can have a tire shop inspect the tire for seperation issues or flat spots.
Jiggerjuice
Oct 5, 2015 02:33 PM
Terry_G35
Sep 10, 2015 08:17 PM
NJ6MT
Sep 10, 2015 08:40 AM
Jiggerjuice
Aug 17, 2015 08:41 AM
TreeFiddy
Aug 10, 2015 06:50 PM
