what offset do i run to avoid rubbing with these tires
Old Nov 5, 2015 | 08:15 PM
noy's Avatar
noy
Hi guys first time G owner here and i'm trying to get some wheels but don't what offset to get. i want to get a wide lip look but do't want to do any rolling of the fender. what is the best wheel setup if i want run 245/35/20 F & 285/30/20 R
Thanks,
Old Nov 6, 2015 | 02:16 PM
nizzan4u2nv's Avatar
Depends. Coupe/sedan, ride height, wheel width, alignment settings, tire brand, fitment preference, etc.
Old Nov 6, 2015 | 05:17 PM
noy's Avatar
noy
i have a coupe and i was hoping someone can give me those info since everyone here has more experience with it than i do. I looked around and found that 20x9.0-9.5 for front and 20x10.0-10.5 might work well. but i'm not sure if i need to do any mod on the fender. i can have alignment do negative camber if needed. but i would like to just be able to mount it with no mod.
Old Nov 7, 2015 | 02:30 PM
GSpeedRevUp's Avatar
If your riding with that wide of rim in the back and want a good offset to get that flush look get your fenders rolled. Especially on the back. I got mine done and have 10" rims with about a +2 offset on them and it runs flush maybe out just a little from the fender. Having a 9.5 front rim you might want to roll the fronts also since your running 20's. I run 19's.
mbolin5
Nov 9, 2015 12:07 PM
DRVNFAST
19 Inch
Nov 6, 2015 04:48 PM
jmathus16
Nov 5, 2015 09:55 PM
