Can a 265 fit on an 8.5" rim?
Old Feb 23, 2005 | 01:04 AM
Gting's Avatar
Can a 265/35/19 fit on a 19x8.5 rim?
Old Feb 23, 2005 | 01:22 PM
sen_jen's Avatar
Meatshake Enterprise
too big. i believe 255 is max.
Old Feb 23, 2005 | 01:30 PM
AmistadUSA's Avatar
NO
245 is MAX.
Old Feb 23, 2005 | 01:31 PM
AmistadUSA's Avatar
Originally Posted by AmistadUSA
NO
245 is MAX.
sorry I mean NO on G35
Old Feb 23, 2005 | 01:51 PM
Rookie84's Avatar
245 is the max on 8.5" wheels. It can fit if you want bulging sidewalls that might rub on the fender... It is not very safe nor benefits in performance even if it doesn't rub.
Old Feb 23, 2005 | 03:27 PM
AmistadUSA's Avatar
I think Mercedes uses 275 on 19x8 for their Maybach
Old Feb 23, 2005 | 05:08 PM
1nate7's Avatar
I am running a 255/35/19 on a 8.5" wheel and the fit is perfect, no sidewall bulge. A 265 would be pushing it and you won't find a tire manufacturer that will recommend it, but I doubt you would have a problem.
Old Feb 23, 2005 | 10:51 PM
baileyrx's Avatar
i've had 255's on my stock 17in rear rear coupe rim (8in) for almost 2 years now. I've even auto-crossed (10times)in these tires. Never had any problems. EVER. No bulge, no funny sounds, no problems. See pictures.
Attached Thumbnails Can a 265 fit on an 8.5" rim?-2004_0306gtires0020.jpg   Can a 265 fit on an 8.5" rim?-2004_0306gtiresg35.jpg
Old Feb 24, 2005 | 06:04 AM
Rookie84's Avatar
I think you are wrong. There is no way in hell M-B is doing such a thing, unless they are going for that mad drag racer look.
Fitting tires on the wheels don't only depend on the width, but also on how tall the sidewall is. For example, 245/45 series tires can be put on 7.5" wheels, but not 245/45 series tires. It also differs from tire companies as the widths vary slightly from one company to the other. I stand corrected about saying 245s are the max on 8.5" wheels since this didn't come to my mind when I posted. Oh wait... I was wrong about 245s being max... Just checked and found out 255 is actually is the widest tires that can be put on 8.5" wheels. My bad.
You can fit whatever you like on the wheels, but I wouldn't suggest going over the limit since they are set for a reason.
Old Feb 24, 2005 | 06:06 AM
Rookie84's Avatar
That's pushing it as 245's are the widest recommended tires on 8" wheels... Just because you don't have problems, that doesn't mean everyone else won't.
Old Feb 24, 2005 | 07:52 AM
copbait's Avatar
You are definitely in the safe range going with 265's on an 8.5" rim. That's an ~81% wheel/tire width ratio (215mm / 265mm), actually just about where you want to be.
Don't let people scare you with baseless theory, let the numbers do the figuring. Also keep in mind that tire manufacturers only recommend a very small range of tires for a specific size rim, in reality there is a larger "safe" range of sizes you can go with that people have been running for decades without any problems. Granted if some moron puts on ridiculously large or small tires bad things will happen, but if you stay right around the 80% wheel/tire ratio on passenger cars you'll be fine.
I would go with 255's on an 8" wheel and 265's on an 8.5" wheel.
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
kevintandmd
Sep 3, 2015 06:41 PM
erich2780
Sep 3, 2015 03:23 PM
