Help on reading tire wall
Old Dec 27, 2016 | 05:37 PM
ShaanK02's Avatar
Smile Help on reading tire wall
So I found these Katana K102 rims that are 19x8.5 for the front and 19x9.5 in the back. These are for my 03 g35 coupe. Could someone please guide me towards the right tires that would give me a decent but not too much stretch? Also I have no cue what bolt pattern I need. This would help SO MUCH.
-Thanks
Old Dec 27, 2016 | 08:03 PM
Blue Dream's Avatar
I drove ttrank's car solo
Moving this to the appropriate place.
Also OP you need to spend a lot of time reading through the wheels/tires sub-forum. Lots of factors come into play when you add new wheels and tires to your car. It's not as simple as the question you asked. Hub pattern is 114.3 FYI.
Also you link requires a download and I for one won't do that. Please edit it and replace it with a link to a specific website or picture or I will delete it completely, thanks.
Old Dec 28, 2016 | 10:51 AM
deeliciousqueen's Avatar
G35 coupe 6mt
Go to this link and plug-in your wheel specs, it tells you minimum, ideal and max size tires. Your questions can be answered by simply using your fingers and eyes. Reading is your best bet.
http://www.tyresizecalculator.com/ty...dth-calculator
