19x10.5
Old May 8, 2018 | 03:11 AM
Rakich11's Avatar
19x10.5
I have a G35 07 Coupe, I recently bought a new set of wheels 19x10.5 all around with 255/35 all 4 tires size, after I drive for a couple of minutes the VDC and Slip lights turn on, do I have to change all 4 tires size or what's the best combination so that the lights don't turn on again?
Thanks for helping !
Old May 8, 2018 | 12:28 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
As long as the tire sizes are within <3% of each other the system will work, I would check to make sure they didn't damage a wheel speed sensor or something during the wheel install. Also get your alignment checked. If you still can't find the issue get a diagnostic from Nissan, their computer tells them what EXACTLY is causing the error.
Old May 8, 2018 | 02:02 PM
Rakich11's Avatar
If all 4 wheels and tires have the same size do they still have a % difference?
Old May 8, 2018 | 04:12 PM
cleric670's Avatar
BANNED!!!
I don't understand what you're asking.
If all 4 wheels and tires are the same size then THEY ARE LITERALLY THE SAME SIZE.
The traction control system needs the front and rear tires to be within 3% of each other, usually you put bigger tires in the rear and smaller tires in the front, that difference in OVERALL HEIGHT needs to be within 3%.
The traction control system can compensate UP TO 3%, if they're the same size there is a 0% difference.
Old May 8, 2018 | 06:21 PM
Rakich11's Avatar
Oooh I get it now, in your opinion what's the best combination I can use in size for front and back tires If I have 255/35's already?
Thanks for helping man !
jserman
19 Inch
Mar 17, 2014 11:55 AM
poktanG35
19 Inch
16
May 11, 2013 03:58 PM
DiscountTireCo
Sep 30, 2003 08:50 PM
blk6pd
May 21, 2003 03:46 PM
RaySur350GT
Mar 28, 2003 07:27 PM
