Does Anyone Know G35 Sedan 6-Speed Stock Wheel Specs?
Old Mar 7, 2005 | 12:42 AM
6speed's Avatar
I'm looking into getting a new set of summer wheels for my car. Does anyone happen to know the offsets for the 17" x 7" stock wheels on the 2004 6-speed sedan? Also, does anyone know what the weight of the stock 17" wheel is? I think I'd like to keep the same wheel size and offset in my new wheels, and I can't seem to find this information anywhere. Thanks for the help.
Old Mar 7, 2005 | 01:05 AM
Gsedan35's Avatar
17x7 45mm offset 23lbs
You can run a 245 wide tire if you select a 8" wide rim, you can also move the tire's out a bit with a 35mm offest and have zero clearance issues.
Old Mar 7, 2005 | 07:58 PM
6speed's Avatar
Great--thanks for the help.
Old Mar 14, 2005 | 01:44 AM
6speed's Avatar
Gsedan35--I just noticed you have the same wheels I ended up ordering (the Enkei RPM2s). Are they compatible with the stock tire pressure monitoring sensors? I'd like to have the TPM sensors pulled from my stock (now winter) wheels and installed in the RPM2s.
Old Mar 14, 2005 | 12:22 PM
Gsedan35's Avatar
Sorry, I have no idea if they are compatible or not. I can only recommend to call Enkei and ask them. Word to the wise, the paint on the RPM2 is on the fragile side, take pain's to protect the rims, especially as your working the lug nuts.
Jusseth
Sep 13, 2020 12:25 PM
Blakelyg35
Aug 15, 2015 12:12 PM
vstypicals
Jul 20, 2015 10:55 PM
realtalk21
Jul 20, 2015 09:07 AM
