need tire size recommendations for 10.5" rear wheel
Hello.
Right now I have 295/35-19 Yokohama AVS tires on a 10.5" Volk GTC at the rear. However, there are fellow g's here running 275's width tires on a 10.5" at the rear and would like your opinions regarding wheel lip safety, looks and overall satisfaction. Pictures would also help too! I was very happy with the 295 rears... the tire width is flush with the wheel and the combo is perfect imho! https://img.photobucket.com/albums/v...tcrearlip2.jpg Thank you! |
what's the offset on those wheels? i think you should just keep the 295.. 275 will look a bit stretched having the rim stick out more than the tire. do you have any more pictures?
I forgot the offsets on these.. I'll post them once I check out the tags on the wheels.
Extra pictures: https://img.photobucket.com/albums/v...earprofile.jpg https://img.photobucket.com/albums/v...ontprofile.jpg I would love to keep these yoko's however they're very bald, pricey and I didn't like the performance. I need to switch out my tires asap! |
10.5" = 266.7 mm... the 275's will still fit okay, but rim protection will be very
minimal if at all. The tire will look a tad pulled. As a reference, Im running 10" and there is some wheel protection with the 275/35/19 S03's. |
What suspension are you running & any rubbing issues w/ the 295's & 10.5's?
I would recommend the BFG KDW2's in 255/35 front and 285/35 rear - I will be running these on 9.5/10.5 Volks as soon as tomorrow, hopefully!
bzabodyn
When you get your new shoes installed, post up pics of them. I was considering the same BFG sizes but not really much of a KDW2 fan. I'll be running 19x9.5 & 19x10.5 and seriously considering the Bridgestone RE050A 255/35/19 & 275/35/19 now. There won't be much lip protection with the 275s for the rear but as long I have some rubber width on the fronts, I think it should be fine WRT protection. panda007 Any issues on rubbing when dropped? |
i had major rubbing issues... however, i have read 275's shouldn't rub at all, although i am not too sure if the cars were dropped or not.
once the camber has been spec'ed out to factory settings, i am probably sure that dropped cars with 275 will have to roll out the fenders. if someone can come and clarifly, please do! bzabodyn, thanks for the recommendation! i will look into those. keep the recommendations coming! oh and accordfreak, my rears are +24 offset. I am not sure about the front offset. |
i think 275's are too small for a 10.5" wheel. definitely keep the 295s!
