Rudimentary question on wheel/tire
Old Mar 14, 2005 | 01:26 AM
haze's Avatar
Being fairly new to cars and specs and so on, I've heard many ppl mentioning 245/40/18 front and 245/45/18's and 275's and stuff like that. Can somebody clarify what each number means and the units?
I can guess that 18 would be a 18" rim.
In addition, what would be stock for our g35? Is there a generally agreed/acceptable limit?
thanks in advance
Old Mar 14, 2005 | 01:31 AM
Boon's Avatar
Coupe or Sedan?
This tool will show you some size differentials,etc.
http://www.miata.net/garage/tirecalc.html
Old Mar 14, 2005 | 01:32 AM
kenchan's Avatar
245mm width
40% of width (245) = profile or width of sidewall
18"
stock is 225/45/18, 245/45/18
since 18x8 wheels, (18" x 8") you're pretty much stuck with these sizes
for optimum fit.
Old Mar 14, 2005 | 04:01 AM
haze's Avatar
Sry, i meant coupe.
So the rear wheel is wider at stock then?
What do you mean we're pretty much stuck with these sizes?
I still don't quite get the middle number, ie 40% of width (245) = profile or width of sidewall, is that the part that is not counted in the tires?
Old Mar 14, 2005 | 02:32 PM
GZire's Avatar
Take a look at this information from Tire Rack:
http://www.tirerack.com/about/techcenter.jsp
Old Mar 14, 2005 | 04:14 PM
CrazyMike's Avatar
An alternate front size is 245/40/18 which is pretty close to the stock 225/45/18 diameter. I intend to get that size when my Pilot Sports wear out...
Old Mar 14, 2005 | 07:59 PM
haze's Avatar
Thanks a lot ppl
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
