Which Tokico D-Spec, Z or G
Old Mar 14, 2005 | 11:06 AM
z_with_back_seat's Avatar
It looks like there are 2 different model numbers for Tokico D-Spec Shocks
DSP-7 for G35's
DSP-9 for 350Z's
I am going to be ordering the Tein H-Spec for the 350z for my coupe but which shock would be better?
Any help???
Old Mar 14, 2005 | 12:23 PM
Gsedan35's Avatar
Go with the Z version. Their is a post floating around in this section of the board where someone actually called Tokico.
Old Mar 14, 2005 | 12:55 PM
thanks
found it
https://g35driver.com/forums/wheels-tires/42971-tokico-d-specs-g35-350z.html
Old Mar 14, 2005 | 01:45 PM
dklau33's Avatar
Agreed. According to Tokico they say that the valving on the G and Z version is the same. But just to be safe I would go with the Z version especially since you are using H-Techs for the Z. Good luck.
Old Mar 14, 2005 | 02:56 PM
kenchan's Avatar
I agree, go with the Z tokico's just to make sure you don't get spring rattling at
full extension.
Old Mar 14, 2005 | 04:11 PM
CrazyMike's Avatar
I really don't think it will make any difference. Just make sure you don't use the stock coupe springs if you use the Z D-Specs since they are shorter...
DRG35R
Sep 16, 2015 05:33 AM
spanky99l
Sep 7, 2015 12:46 AM
TheBay
Sep 3, 2015 03:27 PM
nosam1g
Aug 22, 2015 11:58 PM
linedr89
Aug 17, 2015 05:11 PM
