20's question? can someone pls. ans...
will a 275 35 20 fit a 20x10 rim on a coupe???
yes they will but the best setup is 275/30
^ what the above said, unless you don't mind rolling your fenders. depending on your drop, 30 series would be max imo.
im getting 275/30 ..
That's the size I have. :)
Depends on the brand of tires as well, some are thicker in tread pattern (Bridgestone) some thinner (Toyo). Falken I believe are a size smaller in general, I would go take a look and compare the actual tires.
Go with a 285/30/20 it looks alot better on a 20x10. A 275/35 on a 10" wide wheel is not gonna look good IMO, I have toyo's 275/30/20 on my rears now and I hate the way they look, I just got a set of BFgoodrich g-force 285/30/20 just hope they dont rub.
The 10's will fit. I have 275/35/20 and I went with this size because 275/30 would affect VDC.
James |
so if i'm running 20x10.5 in the back with BFG g-force KDW2, will 275/35 not fit?
James |
RIGHT ANSWER ;) The shape of the tires does matter, but x35 will most likely fit the G Coupe for Rear with no problem :D But I will suggest 275/30R or 285/30R to avoid any potential problems... |
| All times are GMT -4. The time now is 09:43 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
