20's question? can someone pls. ans...
Old Mar 18, 2005 | 11:18 AM
my_Gthang's Avatar
will a 275 35 20 fit a 20x10 rim on a coupe???
Old Mar 18, 2005 | 11:28 AM
crai6m4ck's Avatar
yes they will but the best setup is 275/30
Old Mar 18, 2005 | 11:40 AM
sen_jen's Avatar
Meatshake Enterprise
^ what the above said, unless you don't mind rolling your fenders. depending on your drop, 30 series would be max imo.
Old Mar 18, 2005 | 12:30 PM
paranormal's Avatar
im getting 275/30 ..
Old Mar 18, 2005 | 01:37 PM
waijai's Avatar
i.love.gold
That's the size I have.
Old Mar 18, 2005 | 06:46 PM
shl11111's Avatar
Depends on the brand of tires as well, some are thicker in tread pattern (Bridgestone) some thinner (Toyo). Falken I believe are a size smaller in general, I would go take a look and compare the actual tires.
Old Mar 18, 2005 | 07:59 PM
nismoGcoupe's Avatar
Go with a 285/30/20 it looks alot better on a 20x10. A 275/35 on a 10" wide wheel is not gonna look good IMO, I have toyo's 275/30/20 on my rears now and I hate the way they look, I just got a set of BFgoodrich g-force 285/30/20 just hope they dont rub.
Old Mar 18, 2005 | 09:09 PM
Sponger's Avatar
6MT Brembo Coupe
The 10's will fit. I have 275/35/20 and I went with this size because 275/30 would affect VDC.
Old Mar 19, 2005 | 12:57 PM
CreativeAutoworks's Avatar
You are mostlikely going to rub with that tire. The g-force is a very very wide tire. I can email you a picture comparing a 265 G force to a dunlop 285. The g force is still wider then the dunlop, even tho the dunlop is two sizes larger. Make sure you can get a refund on those tires if they dont fit.
James
Old Mar 19, 2005 | 01:11 PM
Booooz's Avatar
so if i'm running 20x10.5 in the back with BFG g-force KDW2, will 275/35 not fit?
Old Mar 21, 2005 | 04:28 PM
From what my tire charts says, the KDW2's dont come in a 275/35, on the KDW's do. If you want the KDW2's you'll have to deside between the 265/35's and 280/30's
James
Old Mar 21, 2005 | 04:34 PM
AmistadUSA's Avatar
RIGHT ANSWER
The shape of the tires does matter, but x35 will most likely fit the G Coupe for Rear with no problem
But I will suggest 275/30R or 285/30R to avoid any potential problems...
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
