G35C Eibach Prokit!
Old Mar 21, 2005 | 04:29 PM
falcon50driver's Avatar
G35C Eibach Prokit!
Just finished installing the Eibach Prokit this afternoon.I am running Toyo Proxes T1S 19/245's in front and 19/275 rear.Pretty pleased with the results.The car lowered as advertised 1-1/4 front and 1" rear.I don't think they will settle much (being progressive springs). Camber needed to be adjusted rear, and I am within spec's with the stock camber adjusters.The fronts needed minor adjusting (toe in toe out) with slight negative camber(no front camber adjustments provided) Fender clearance is more than sufficient,in fact, another 1/2" or so would be nice, however, after market camber adjusters would probably be necessary.I hope this info was helpful to those looking at the Eibach Pro Kit.
2004 G35C MT6
Diamond Graphite/Graphite
Aero package
Grounding kit
Z-tube
Axis Hiro 19-9 f 19-9.5 r with Toyo Proxes T1S 245/275
Old Mar 21, 2005 | 05:36 PM
wckdg35's Avatar
Just got mine installed too. Haven't had it aligned yet, but thanks for the heads up
Old Mar 21, 2005 | 09:09 PM
kenchan's Avatar
actually, it is usually the exact opposite. Linear springs don't settle as much.
Your prokit will settle close to 1/2" wait and see. then get your alignment
done again. my rear sits -1.4"
Old Mar 22, 2005 | 08:37 AM
Spring settle
I hope they do settle a bit more, and yes, another alignment would be the thing to do after a while. In fact, most new cars may be out of alignment to a certain degree from the factory since they run 30 to 40 cars through a standard predetermined alignment, then recalibrate.
Old Mar 22, 2005 | 02:47 PM
wckdg35's Avatar
Mine settled just right
seagrasser
May 3, 2022 09:43 AM
Kelvin Style006
May 23, 2016 03:47 AM
Soumilg
Jul 23, 2015 09:26 AM
Soumilg
Jul 18, 2015 12:33 PM
