will this work?
Old Apr 11, 2005 | 06:47 PM
Need4SPEED05's Avatar
will this work?
I am looking a set of 20" rims. 20x8 front offset: 20mm and 20x10 offset: 35mm in the rear. will this work on my g35 coupe? Suspension is stock and can I go with 245.35.20 and 275.35.20 tires? Sorry guys, I know there are alot of posts about this but I don't see any with the same specs. Will the 8 inch wide tires look funny in the front? I don't want it to be too inside the fenders or anything.
Thanks
Old Apr 11, 2005 | 07:27 PM
Sorry the fronts are 8.5 not 8
Old Apr 11, 2005 | 09:12 PM
CreativeAutoworks's Avatar
8.5 and 10 will be fine.. dont worry...
Old Apr 11, 2005 | 09:28 PM
so the offsets are good and i can put 275/35/20 in the rear no problem? The reason I ask is because I see alot of people are running 275/30/20 in the rears, but I'm trying to get a little more sidewall.
Thanks
Old Apr 12, 2005 | 12:14 AM
absgtr's Avatar
ur better off 275/35, with a 20" wheel it helps to have more sidewall for protection
Old Apr 12, 2005 | 11:13 PM
ok kool...thanks...Yeah...I wanted 275/35 in the back but was afraid of rubbing. I don't want to have to roll the fenders and my last car had rubbing problems so I don't want to have to deal with that again. I'm not lowering it either so it should be ok...I hope.
arora_g35
Apr 16, 2026 02:52 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
JMSABO
Aug 4, 2015 11:58 AM
attarday
Jul 15, 2015 04:03 PM
