350Z wheels on G35 sedan
Old May 26, 2003 | 12:51 AM
mtn's Avatar
mtn
Will the 350Z wheels fit on the G35 sedan? Does anyone know or even tried this?
Old May 26, 2003 | 07:22 PM
FDNameBrands's Avatar
Re: 350Z wheels on G35 sedan
I think they have the same bolt pattern, but I'm not 100% sure though.
Old May 26, 2003 | 09:50 PM
GForce35's Avatar
Yes they will. I just put the 350Z six spoke 18x8 30mm offset on my sedan and they look great. Bolt pattern is the same and you can even replace the Nissan center cap with the Infinity center cap from your 17" wheels. See pics in the rides section page 5 under "GForce35."
<P ID="edit"><FONT class="small"><EM>Edited by GForce35 on 05/26/03 07:30 PM.</EM></FONT></P>
Old May 26, 2003 | 10:38 PM
This is GForce35's ride, hope you don't mind Gforce. BTW, It looks really nice.</p>
<img src="https://g35driver.com/rides/spec/pix/GForce35_1054001632.jpg" width="450" height="337"></p>
<img src="https://g35driver.com/rides/spec/pix/GForce35_1054001699.jpg" width="450" height="337"></p>
<img src="https://g35driver.com/rides/spec/pix/GForce35_1054001757.jpg" width="450" height="337"></p>
<img src="https://g35driver.com/rides/spec/pix/GForce35_1054001876.jpg" width="450" height="600"></p>
<img src="https://g35driver.com/rides/spec/pix/GForce35_1054001958.jpg" width="450" height="600"></p>
Old May 27, 2003 | 08:04 PM
GForce35's Avatar
Nope, don't mind at all FDNameBrands. Tried to attach the images myself, but I didn't know how. Thanks
<P ID="edit"><FONT class="small"><EM>Edited by GForce35 on 05/27/03 05:16 PM.</EM></FONT></P>
Old May 28, 2003 | 09:49 AM
Rumble's Avatar
The wheels look like they stick out of the fender a bit...hmmmmm. Nice ride, however they don't look like 18s in the pictures. Maybe you can consider dropping the car a tad. [img]/w3timages/icons/smile.gif[/img]
It's still a G thang!!
Old May 28, 2003 | 10:46 PM
GForce35's Avatar
I thought so to when I first saw it after the wheels were put on, but the tires are actually flush with the fenders. Haven't had any problems with them rubbing or hitting anything as of yet and I hope I don't :>( I didn't think the 245's would be a problem since my area dealership puts on 18" after market wheels with 245's on the sedans on their lot. I haven't read any posts with 245's being a problem. Also, I'm not really into dropping the car, maybe its because I'v seen so many honda civics around here where the driver is in danger of getting rectal rash. No offense to those guys! Thanks for the input.
Old May 29, 2003 | 02:51 AM
Gsedan35's Avatar
I highly doubt that the dealer is installing 245's on rims with 30mm offset. Do not go with 245's in the front if you have less than 40mm offset. The rear is a different story, the is fender out more, allot more forgiving. I have 245's on 45mm offset, in the front when the suspension compress's for cornering, their's not much room from the fender lips in the front. Again the rear has ton's of room.
Ivry 6mt sed
Injen CAI, 22" resonator
8X18 Enkei RPM2 45mm
Kumho MX 245/40
clear corners
Old May 29, 2003 | 03:53 AM
My6speedCoupe's Avatar
i think he s gonna rub if he lower the car....what s the offset on stock Sedan rims?
Old May 29, 2003 | 02:47 PM
GForce35's Avatar
They were free and from a Z with only 2000 miles on it, except that one had some minor curb rash. I sent the rim off and had it fixed for $150.00. Just don't have the $2000+ at this time for the Momo's I want, but these will do for now. I drive aggressive and have had no problems thus far. Can always put the tires on something else later. Thanks for the comments.
<P ID="edit"><FONT class="small"><EM>Edited by GForce35 on 05/29/03 11:49 AM.</EM></FONT></P>
Old May 30, 2003 | 10:18 AM
Rumble's Avatar
I would like a set for free as well, please. [img]/w3timages/icons/smile.gif[/img]
Old May 30, 2003 | 11:01 AM
Gordgee's Avatar
Administrator
Me too![img]/w3timages/icons/smile.gif[/img]
<font color=green>GG</font color=green>
Old May 30, 2003 | 11:48 AM
GForce35's Avatar
Sorry guys, got lucky on this one. Happened to be in the right place at the right time :>)
