8.5" front & 10.5" rear
Old Apr 19, 2005 | 07:06 PM
frofan's Avatar
Most people run 9.5 & 10.5 or 8.5 & 9.5, what are the pros or cons of running 8.5 & 10.5?
Old Apr 19, 2005 | 08:07 PM
frofan's Avatar
a couple auto-x and maybe track days next year, so I want something that isn't just straight line performance.
Old Apr 20, 2005 | 12:05 AM
kenchan's Avatar
Im running 8.5 on the front and 10 on the rear. 245 front, 275 rear S03's.
with the swaybar, strut/shocks/spring rate, and alignment settings i can induce
over steer at command while the car is very predictable and neutral through
fast turns.
toying around with swaybars will net better turning behavior of your car
than playing with wheel width alone.
Old Apr 20, 2005 | 10:02 AM
LUV2DRIVEMYG35's Avatar
Originally Posted by HomieG35
Tnen you'll probably want the 9.5 [atleast] in the front. I've heard for RWD cars these have some...understeer? So you'll want the front to really bite and turn and not slide like a FWD car would do. I'll wait for someone else to chime in!
Can the coupe take a 9.5 in the front w/o fender mods? What offset would you recommend, +40? I'd be interested to put 9.5's upfront if I could. Thanks.
Old Apr 21, 2005 | 01:47 AM
ZeroGen's Avatar
Omega Enthusiast
+40 offset up front would be too high for a 9.5 inch wide rim. I have the Brembos up front and have +20 offset with plenty of clearance between the wheel and brake caliper. I would tend to think that in the +20 to +26 range would be sufficient (approximate) to clear the Brembos. Try doing a search on what some folks are running.
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
