Question for people running 19x10 in rear
Old Apr 21, 2005 | 10:18 PM
skylineg35tt's Avatar
For the people that are running 19x10 in the back and have dropped there car,
have you guys ran into problems? Such as scraping..etc. It seems like the wheel sticks out a lot and might scrape the body when you have people sitting in backseat while going over bumps.
Also if you have dropped, what springs? And did run into camber issues?
Old Jun 17, 2006 | 01:04 AM
JEVERYDAY's Avatar
I have that problem now. Whenever I hit a bump my wheels scrape.
Old Jun 17, 2006 | 02:40 AM
caskyline's Avatar
Former Vendor
It all depends on the offset and design of the rim.There are people 10.5" with no problem.I am running 10" rear rim with a 4" lip and 285 x 30 tire with a camber kit set for max tire life.I never rub on the fenders even with 4 people in the car.
Old Jun 17, 2006 | 02:47 AM
papagz's Avatar
^^ plus 1 also depends on your drop.
Old Jun 17, 2006 | 07:11 PM
jxtg35's Avatar
I am running 19x10.5 275 30 r19, if I remember correctly the offset was +19 with a 4.5 inch lip. I'm lowered 1 inch and have no rubbing problems. Rubbing has alot to do with the correct offset, get the proper offset and you will be fine with a mild drop.
Old Jun 17, 2006 | 08:46 PM
MikeyMike's Avatar
Rollin On Dubz
Exactly...lot of factors come into play like offset, tire size, camber, etc...
Jusseth
Sep 13, 2020 12:25 PM
rezendvous420
May 31, 2020 01:26 PM
Soumilg
Jul 18, 2015 12:33 PM
