Quote:
Originally Posted by JUAN
So I personally think, my opinion is that they're the same only with different names....
I think that's a false statement. The LS/LS+ series is meant for a luxury comfort ride with some better handling characteristics. The RS is marketed as a compromise between a street/track system. The LS+ uses aluminum upper mounts with rubber bushings for comfort, less noise. The RS uses upper pillowball mounts that are stiffer to maintain suspension geometry. And the biggest differene between the two has got to be the shock valving. I would bet the LS+ and RS coilovers are valved quite differently.
Quote:
Check my other tread: https://g35driver.com/forums/wheels-tires/56592-silver-ken-say-bye-20-s-hello-19-s-r5-black-hks-rs.htmlOriginally Posted by areddy14
juan, with the rs, is a rear camber kit neccesary? if so, how much do those run? thanks.
This is what I did after selling my 20"s.
Quote:
Its a wierd feeling I have, don't you get those sometimes Originally Posted by dklau33
Sometime companies change names on the same products in order to sell everthing.
But anyway you could be right
I'm interested in why you think they are essentially the same product? What else besdies the similar spring rates makes you think that?Originally Posted by JUAN
