Wheel Fitment
Old Apr 27, 2005 | 01:04 AM
mmpotash's Avatar
Wheel Fitment
I am possibly buying used non OEM rims with winter tires for a 2005 G35 6sp coupe. They were bought by the seller from tirerack for his 2003 auto coupe.
The size of the rims, I think, is 17-8 with an offset of +35. The problem of fitment may be in the front wheel, which has a tire width of 235. The brakes are not a problem. The problem may be the strut clearance. I checked the difference compared to the OEM 17" wheel of the 2004 coupe, and with the different offset, 30 vs 35, and the 10mm wider tire, the tire will be 16mm closer to the strut behind the tire.(11mm closer due to the offset difference + 5mm due to the 235 vs 225 width tire that would come with the rim). I've heard that the G35 OEM coupe wheels will fit the 2005, but I'm not sure.
Does anyone have any insight on whether the 17-8 +35 will work on the 2005 6sd coupe? Or, does anyone know the offset of the 2005 coupe 17" and 19" rims? If the 17" 2005 coupe rims offset has not changed from the 2004, that would give me a better idea if it would work.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
joedaddy1
Jul 28, 2015 02:58 PM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
