Will '03 Brembos bolt on to '05 ?
I am planning on updating to an '05 or '06 soon and I am wondering if it is worth it to keep my original '03 Brembo's and do a swap? Does anyone know if the mounting points are the same? I am assuming the rotors are different sized but can I get a confirmation on this please.
Thanks!!
Thanks!!
I would imagine you would probably need the spindle as well. Could be possible that the only difference is the mounting holes on the actual caliper. Just have someone with 05 measure the distance between 2 bolts. and compare them to yours.
You could just order a set of stoptechs as well, unless your getting a bomb price on the used brembo's you may want to consider a BBK.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
AuAltima3.5
Sep 13, 2015 10:53 AM
