D-spec,eibach
Old May 14, 2005 | 05:42 PM
G35ZRUSH's Avatar
D-spec,eibach
Can I Use Eibach Spring And Tokiko D-spec For Nissan Z To My G35 Coupe?
Old May 14, 2005 | 08:48 PM
kenchan's Avatar
the Eibach for Z will be too low for our coupes, *I think*. (not 100% sure).
The prokits I use for my G was pretty darn low...so add another ~1" lower.
Old May 15, 2005 | 02:22 AM
Gsedan35's Avatar
Yes, but they won't drop your coupe the same amount that they will drop the Z.
350Z Eibach's on a 350Z lower the Z 1.0". Same spring used on a G coupe you will see at least 1.5" of drop. Their are better performance spring option's if that's what your after just to say it.
Old May 15, 2005 | 10:13 AM
kenchan's Avatar
So if it lowers a Z by 1", then don't you add another 1" for the strut length difference
to get about a -2" lowering? that's wat I meant and I think it's too low
way out of the G's sus geometry.. I think my lowering is about as max
as you can go on a lowering spring while maintaining performance...otherwise
go much higher spring rate (coilovers) and limit the movement.
Old May 15, 2005 | 12:14 PM
Gsedan35's Avatar
Originally Posted by kenchan
So if it lowers a Z by 1", then don't you add another 1" for the strut length differenceto get about a -2" lowering? That's wat I meant and I think it's too low way out of the G's sus geometry.. I think my lowering is about as max
No, you don't add 1", you add 1/2" This is because the 350Z's oem ride height is 1/2" lower then on the G35 coupe.
Example
RSR 350Z springs will drop a Z .6" Same spring if installed on a G35 coupe will drop the coupe 1/2" more then when installed on a 350Z giving you at least a 1.1" drop.
Not to confuse, but on sedan's you must add 1" when using any 350Z based lowering spring. For G coupe's you add just 1/2"
Old May 15, 2005 | 02:24 PM
kenchan's Avatar
oh yah,
Coupe add ~0.5"
Sedan add ~1"
seagrasser
May 3, 2022 09:43 AM
Kelvin Style006
May 23, 2016 03:47 AM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
DRG35R
Sep 16, 2015 05:33 AM
