Few Questions about lowering with 19"s
Old Jun 10, 2005 | 06:23 AM
achen's Avatar
Hey guys. I've been reading about suspension upgrades and lowering springs. I'm planning to get Volk sf challenges in 19x9.5 and 19x10.5 within a few weeks and I'm also thinking about lowering my car just a little bit. Since I want to lower for mostly comestics and I also want to maintain stock ride quality, I decided to do springs, and shocks instead of coilovers. I'm considering the tokico dspecs with H-techs (both for the G35). My question is, have any of you guys done this setup and if so, did you guys have any camber issues? Even if you didn't have this exact setup, did you have any camber issues? I really don't want to get the shocks and springs and then later find out that I also need a camber kit as well (expensive ). If I'm going to have alignment issues, I guess I'll pass on the drop. Thanks for any help guys.
Old Jun 10, 2005 | 11:15 AM
Inf4life's Avatar
i've got the Tein H-Techs on mine and i have a little camber in the back....front seems fine....i do have some rubbing issues but that is due more to the offset on the rear rims than anything....
Old Jun 11, 2005 | 12:07 AM
paul18t's Avatar
Bump. I'd like to know this also. Hopefully a 1 inch drop doesn't require a camber kit. Thanks!
Old Jun 11, 2005 | 12:24 AM
hhg35's Avatar
If you want to play it safe, change shocks only. Almost always, if you change springs on g 35 will get alignment issue. i changed to bilstein and happy with it. I like to lower a little, but passed because of alignment issues.
Old Jun 11, 2005 | 02:46 AM
achen's Avatar
Can you lower by changing shocks?
Old Jun 11, 2005 | 03:15 AM
hhg35's Avatar
No shocks will not lower, it will improve handling.
Old Jun 11, 2005 | 01:13 PM
Keith N's Avatar
Tein 350Z H-Techs W/Volk SF Challenges
Here's my G35C with no rubbibg issues. The drop was approx. 0.7" with no alignment problems. The tire wear is even. The ride is a little firmer than stock with much better control. I'm happy with the setup.
Wheels
Manufacturer: Volk
Model (including finish): SF Challenges
Size (front/rear): 19 / 9.5 F, 19 / 10.5 R
Offset (front/rear): +28 F, +23 R
Purchased from: Wheel Options
Tires
Manufacturer: Toyo
Model: T1 - S
Size (front/rear): 245/35/19 F, 275/35/19
Suspension
Manufacturer: Tein H - 350Z
Attached Thumbnails Few Questions about lowering with 19"s-copy-dsc00514.jpg   Few Questions about lowering with 19"s-copy-dsc00507.jpg   Few Questions about lowering with 19"s-copy-dsc00504.jpg
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
