question about my RS coilovers
Old Jul 11, 2005 | 10:09 PM
areddy14's Avatar
I just received my HKS RS coilovers in the mail today, but i'm facing a problem. I was planning on dropping the car an inch at the most. So should I just get the camber kit now and save two alignments, or do you think there's a chance I'll be fine without it? What would I need to get my specs back to OEM? Thanks.
Old Jul 11, 2005 | 10:31 PM
Cactus's Avatar
Get it now young Jedi!
Old Jul 11, 2005 | 10:56 PM
areddy14's Avatar
Can someone link me to what I need? I'm clueless when it comes to camber kits, etc. Thanks.
Old Jul 11, 2005 | 11:17 PM
Gsedan35's Avatar
I replied to your pm, it it you'll find links and a short run down that I hope helps.
Old Jul 11, 2005 | 11:34 PM
kenchan's Avatar
On coilovers going for a performance setup, I would lower the car no more
than 3/4", get it corner balanced, and then get an alignment done without
adding anything else.
If you're going for dressup, you've got to drop it more than 1"
Old Jul 11, 2005 | 11:48 PM
kenchan's Avatar
without adding anything else (meaning camber correction).
I would add swaybars and run wider, sticker tires, if needed.
Old Jul 12, 2005 | 12:03 AM
G35pm's Avatar
Get a lifetime alignment. Mine has paid for itself already.
Old Jul 12, 2005 | 12:29 AM
skeleton_cru's Avatar
Sedan
I agree. Install the coilovers and adjust the ride height to your liking. Afterwards, get an alignment done and see where you're at. You may not need as much as you think, especially if you only drop 1" or less.
Old Jul 12, 2005 | 12:38 AM
Gsedan35's Avatar
Keep in mind that a sedan that is dropped 1" only equal's a coupe that is only dropped a 1/2". Go past a 3/4" drop on a coupe and staying within oem alignment specs is much in doubt.
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
