New EIBACH G35c Pro-Kit LOWER than Advertised
Old Jul 3, 2003 | 11:38 AM
RugRatCoupe's Avatar
RugRatCoupe
20 Year Member
Just Installed the New G-35c Eibach Pro-Kit.
The advertised Drop is: Fronts -0.7"
Rears -0.5"
However the actual drop on my Car was:
Fronts -1"
Rears -0.7"
These measurments were taken in the same spot in my garage. I think this really changed the looks of the Car for the Better & no scraping so far even w/ the speed humps in my Nieghborhood. More PICS. on Page 11 in the Rides Section...
Old Jul 4, 2003 | 02:34 PM
wreck's Avatar
Running for his life!!
Re: New EIBACH G35c Pro-Kit LOWER than Advertised
I have to agree with rugratcoupe. My car has settled, and the front dropped more than the rear. HE is pretty dead on with his measurements. Still the car turned out nicely.
Here's a before and after picture I took. You can see the front lowered a bit more than the back.
G35C 6MT / E55
Old Jul 6, 2003 | 09:02 PM
dgussin1's Avatar
what size are your tires? do they rub?
Life is to short to argue on the Internet!
Old Jul 8, 2003 | 01:00 AM
VQ35DETT's Avatar
Hey whats the time frame from the before and after shots of your G?
Chris
on order
03 6sp coupe
B/B
Prem,Navi & Aero
*coming soon*
19 TE37
Tien susp
TT kit
Old Jul 8, 2003 | 01:03 AM
wreck's Avatar
I lowered my car a week after I got the rims. The after picture was taken 3 weeks after I lowered it.
dgussin1, I don't rub.
G35C 6MT / E55
Old Jul 10, 2003 | 06:40 PM
DallyCurtis's Avatar
FACK
that is sooooo nice dude ..
I WANT
I neeeeeed
laterrr
Old Jul 11, 2003 | 06:43 PM
Rumble's Avatar
I have a sedan with Eibach's and stock 17s. The rear has pretty much settled and I can't stick a straight finger in the rear at all. It has to be bent upwards. The front is about one straight finger only. I actually wouldn't mind going even lower, but what can ya do? [img]/w3timages/icons/smile.gif[/img]
It's still a G thang!!
Old Jul 16, 2003 | 08:54 PM
ramo's Avatar
how did the ride change after you put on the eibach springs? is it a lot stiffer than stock?
Old Jul 16, 2003 | 09:25 PM
wreck's Avatar
IMHO it rides the same.
G35C 6MT / E55
Old Jul 16, 2003 | 09:52 PM
Gsedan35's Avatar
The Eibach's feel the same cause they pretty much are the same, the differance is the progressive bit, a compromise between comfort and performace.
Stock spring rates
350Z: 347/419
G35 coupe and sedan sport: 357/407
Eibach 350Z spring rates front 296/384 rear 316/421
Eibach G35 sedan front 259/334 rear 359/413
(I don't have coupe eibach coupe rates, but I'm postive they'll be the same as the sedan's)
Notice the high numbers for the front and the rear are real close to the numbers for the the stock springs, that's what I mean, their pretty much the same.
Ivry 6mt sed
Injen CAI, 22" resonator
8X18 Enkei RPM2 45mm
Kumho MX 245/40
clear corners
Old Jul 17, 2003 | 02:34 PM
Vancouver_G35's Avatar
Why are there two numbers for the Eibach spring rates? Is it because they are progressive and the numbers are range of the spring rate depending on the compression?
Old Jul 20, 2003 | 11:14 PM
mountain's Avatar
so which eibach springs are these numbers from? I just removed the JIC FLTA2 suspension from my car and went to stock (Too low (my fault they are adjustable) and too hard). I want to lower the car (it looks funny after being lowered for months) but dont want to give up the ride? Which springs should I get. I only want to lower it about 1 inch and keep the same ride comfort.
Old Jul 20, 2003 | 11:27 PM
Gsedan35's Avatar
Vancouver_G35 (registered)
07/17/03 11:34 AM
__________________________________________________ _
Yes, Eibach show's you the softer progressive rate first. The second higher rate take's effect once the softer part of the springs coils bind together. At that point your riding on the higher spring rate.
Ivry 6mt sed
Kumho MX 245/40
350Z springs&struts
Old Jul 20, 2003 | 11:31 PM
Gsedan35's Avatar
mountain (journeyman)
07/20/03 08:14 PM
The G35 rates I have are for the sedan application.
Based on what you want you the eibach's would be the best choice. Performance wise, a non progressive linear spring would be better. But with ride quality looking like it's priority number one for you, go with the eibachs.
Ivry 6mt sed
Kumho MX 245/40
350Z springs&struts
