H&R 25MM On 05 6MT Coupe Rear
Old Sep 6, 2005 | 03:19 PM
regrossman's Avatar
Can anyone tell me if the H&R Spacer with the integrated studs would work well to make the OEM 19 even with the fender. I don't want to be sticking out to far or have rubbing issues. Going to be installing Tein S Tech springs as well. H&R says the spacer is 25MM. Thats the smallest one they sell that has integrated studs.
Old Sep 12, 2005 | 03:16 PM
regrossman's Avatar
Anyone?
Old Sep 12, 2005 | 10:49 PM
baileyrx's Avatar
h&r 25mm spacers on my 17in 2003 coupe plus 1 &1/4 in drop
those last 2 are from this past feb. (75+mph) no touching
Attached Thumbnails H&R 25MM On 05 6MT Coupe Rear-dscf0034.jpg   H&R 25MM On 05 6MT Coupe Rear-dscf0043b.jpg   H&R 25MM On 05 6MT Coupe Rear-dscf0037b.jpg   H&R 25MM On 05 6MT Coupe Rear-virpro-003forg35.jpg   H&R 25MM On 05 6MT Coupe Rear-virpro-001forg35.jpg
Old Sep 12, 2005 | 10:50 PM
baileyrx's Avatar
i think it the perfect "bump out" for stock tires. Fills the wheelwell out nicely
Old Sep 13, 2005 | 02:17 PM
regrossman's Avatar
What are the offset of those stock 17s? MY wheel is a half inch wider and 33 offset i believe. I want mine to sit like yours, closer to fender, no rubbing though.
Old Sep 13, 2005 | 02:34 PM
Finiti35's Avatar
FGC South Florida BOD
I'm pretty sure that OEM 17" are only 7.5" wide. Bailey is brave to run 275's in the back on those wheels. And yes the rear offset on ours is 33mm, I was thinking about spacers too, but I want wider tires also. Might as well get aftermarket wheels eventually.
Old Sep 13, 2005 | 02:44 PM
regrossman's Avatar
Those are 275 on a 7.5" wheel? I would like to be able to put a 285/35/19 on the stock rear 19" wheel. I like a little buldge look if thats all it would have.
Old Sep 13, 2005 | 09:56 PM
baileyrx's Avatar
the stock rears on the coupe are 8in wide. I have 8in wide(255's) in the front.
the 275's are the largest I'd probably go on an 8in rim.
Lots of people say "wow that's way too wide", but I've auto-crossed a bit & have seen some even crazier sizes.
Brodys_GCoupe
Nov 7, 2015 08:06 PM
Kal Hamm
Jul 24, 2015 08:55 AM
driftsucky
Jul 15, 2015 12:38 PM
