what coilovers can drop the most?
Old Sep 16, 2005 | 04:50 AM
nyckid's Avatar
i was looking between the tein basic and the tein cs... and when looking at the specs, it seems like the basics can drop the car lower than the cs? is that right? it says that it can drop the front anywhere from .07in to 2.6in and the rear from .04in to 1in...
not sure about the HKS coilovers... really want to slam my car, but not sure which coilovers can give me a greater range in ride height adjustablity... i thought you could drop more than 3in" with coilovers?
Old Sep 16, 2005 | 09:50 AM
Diesel1's Avatar
Moderator
Paul formerly of Eastern had the CS on his car and it was slammed. Keep in mind if you wanna slam it, you will def need a great camber kit! I just bought mine for the anticipated Basics that will be installed soon. I believe the SPC rear camber kit is probably the best and least expensive of the bunch. It provides adjustability +-4 where as others are around +-3.
If you want a CS system cheap with or without EDFC, lemme know! Shoot me a PM
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
