RX8 wheel bolt pattern fit g35?
Old Sep 29, 2005 | 12:49 PM
ericsherbrooke's Avatar
Do you know if a wheel setup from a RX8 would fit the bolt pattern of a g35 coupe?
Old Sep 29, 2005 | 01:50 PM
dklau33's Avatar
If the RX-8 has a wheel bolt pattern of 5x114.3 then yes.
Old Sep 29, 2005 | 02:53 PM
if I understand correctly, 5x114.3 is the pattern for the g35.
Does it mean:
5 bolt on a 114.3 mm bolt circle?
I will now search for the RX-8 wheels value to compare.
Thanks, anymore info is welcome.
Old Sep 29, 2005 | 02:56 PM
MikeyMike's Avatar
Rollin On Dubz
Ask the Mazda dealer what the bolt pattern is for the rx8
Old Sep 29, 2005 | 02:59 PM
Look what I found..
http://www.ronalusa.com/cars.html
I found a used winter setup wheel from a rx8 owner, wanted to confirm that it could fit.
now the only way to know if it fit over the brembo is to try them on?
Old Sep 29, 2005 | 06:59 PM
dklau33's Avatar
Does it mean:
Yes, 5 means 5 bolt holes and 114.3mm is the distance between each hole.
Old Sep 30, 2005 | 01:55 AM
wayneside's Avatar
the offset is different...i used to have an RX8 and the wheels I had for a 350Z stuck out about an inch and a half...rubbed on the fender like there was no tomorrow...
but they do have the same lug pattern...
laksjd84
Jul 24, 2015 05:12 PM
