Need some helps on wheels and tires setup
Old Sep 29, 2005 | 06:19 PM
squll's Avatar
Hey guys. Need some helps on wheels and tires setup. I am still learning and would like to ask few questions.
Currently, I like to get Ruff Racing 278 wheels for my G. I am thinking to get 18” instead of 19”. I like the look 19” tires on the car. But I think 18” tires may give better ride. I called around and the spec I get is the following.
Ruff Racing 278 Wheels:
18 X 8.5 (F)
18 X 9.5 (R)
20mm for Brembo brakes (I have Brembo brakes on my 04 G35 Coupe 6MT)
Tires suggestion:
245-40-18 (F)
275-35-18 (R)
Is it a good setup?
I saw somewhere about 245-40-18 (F) and 255-45-18 (R) for the best stock tires setup. So, I was kinda surprised when I hear this Ruff Racing wheels needs 275-35-18 for the rears. Any input would be helpful. Thanks much!
Old Sep 30, 2005 | 12:20 PM
squll's Avatar
Anyone can help???
Old Sep 30, 2005 | 05:58 PM
g35doc's Avatar
You want to go 275/40/18 in the rear to maintain the stock diameter and stagger. 255/45/18 is commonly used but a little taller than desired. Spoke design and not offset determines if the wheels will clear the brembos, although a lower offset will help. Try a test fit if you can.
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
