G35C coilovers
Old Oct 5, 2005 | 10:45 AM
DefJukie's Avatar
G35C coilovers
Hey i had a quick question for you all, are all 350z coilovers interchangeable with the g35c?, when i look around, some coilovers say for both g35 and 350z but others only say 350z, more specifically, will the cusco zero2 for the 350 for on a g35??, thanks ahead of time
Old Oct 5, 2005 | 10:52 AM
Lucino's Avatar
They should be interchangeable
Old Oct 5, 2005 | 12:04 PM
Gsedan35's Avatar
They are. Though, word to the wise. Some 350Z coilover's like Jic FLT-A2's have a earned reputation of being quite harsh. And you'd do well to avoid any 350Z coilover system that uses spring rates over 12kg or 672lbs. Cusco's would be a good choice, I would not run them with the pillowball upper mounts, choose the hard rubber mounts they also have.
With the Cusco Zero 2's, you get a adjustable dampner, monotube construction vs twin tube and they feature full length adjustment so you can adjust ride height without adjusting spring preload to get it. Their is a set for sale used on 350Zmotoring.
Old Oct 6, 2005 | 10:37 PM
jzz311jz's Avatar
350z coilover from JIC are harsh on a g35 therefore JIC has specific part number for our G35's. Gotta remember though....it's all in the setup and the application of your ride. I have flta2's in my g and the ride is great.....gotta also remember...the stiffer the car/ setup it's obvious ride will also be stiffer.
Old Oct 21, 2005 | 07:43 PM
damen's Avatar
the part number for the G35 coupe is CPV35FLTA2 i was looking to get a set but, i think i'm going go hold off for now because i was to keep the stock height and ride. going with JIC set up i'll be lowering my car by at least .5".
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
