Is my camber way off after my new wheels? <<<<<<PICS>>>>>>
Oct 6, 2005 | 11:15 PM
I got my new wheels Volk GT-AV Gloss Black 19" 8.5 et 24 & 10.5 et 23 with Toyo T1-R 245/35/19 & 275/35/19. I don't plan to drop my car so, I went for an alignment and the print out below shows my current alignment status. I got the lifetime alignment from firestone ($99)
Do you think the camber is off? Will it cause excessive inner/inside tire wear?
More pics can be found here https://g35driver.com/forums/picture-share/70413-black-beauty-pics-56k-beware.html
Is my camber way off after my new wheels?  &lt;&lt;&lt;&lt;&lt;&lt;PICS&gt;&gt;&gt;&gt;&gt;&gt;-alignment-lo.jpg   Is my camber way off after my new wheels?  &lt;&lt;&lt;&lt;&lt;&lt;PICS&gt;&gt;&gt;&gt;&gt;&gt;-pa031660-large-.jpg
Reply 0
Oct 6, 2005 | 11:28 PM
i dont know anything about camber.........but those wheels are tite.........lets see them mounted
Reply 0
Oct 6, 2005 | 11:47 PM
Your front are fine. Your back is off. There not within specs. Go pick up SPC Camber adjustments if you want something cheap that works.
Reply 0
Oct 7, 2005 | 12:07 AM
wow...lot of numbers lol
i need to learn how to read that thing haha
Reply 0
Oct 7, 2005 | 12:17 AM
you are off by a LITTLEE bit. honestly thats nothing. i wish i could show you my camber specs. my mechanic gets is very close every time and in all honesty that small of a difference will not make a huge impact. now if your not comfortable w/ it thne you can get camber arms. but i dont think its worth it for such a small amount. the left rear is a bit off, but make sure he maxed out the positive camber. unless you dropped it the car shouldnt have a camber issue. take it back say they didnt do it right..
Reply 0
Oct 7, 2005 | 01:01 AM
Quote: you are off by a LITTLEE bit. honestly thats nothing. i wish i could show you my camber specs. my mechanic gets is very close every time and in all honesty that small of a difference will not make a huge impact. now if your not comfortable w/ it thne you can get camber arms. but i dont think its worth it for such a small amount. the left rear is a bit off, but make sure he maxed out the positive camber. unless you dropped it the car shouldnt have a camber issue. take it back say they didnt do it right..
I agree with what papagz said ^^^. My specs have the same numbers you have, and I've been doing fine with about almost 17,000 miles on my tires already.
Reply 0
Oct 7, 2005 | 01:15 AM
Great choice on wheels!!! But of course I would be a bit bias, considering:
[IMG] [/IMG]
I got the same rims BTW did your wheels come with center caps, because my set didn't
Reply 0
Oct 7, 2005 | 01:17 AM
NUTS what are you dropped on? front looks like my drop something like 2 inches lol
Reply 0
Oct 7, 2005 | 01:20 AM
Quote: NUTS what are you dropped on? front looks like my drop something like 2 inches lol
Tein H-techs (350Z). It's not really that low, maybe it's the Nismo front that gives it that illusion.
Reply 0
Oct 7, 2005 | 01:56 AM
ya prob that..my car looks like that kinda, except its dropped like 2 inches and over. those springs are crazy low, stock shocks??
Reply 0
Oct 7, 2005 | 03:22 AM
at least you got your toe fixed. I bet you were burning through tires. Your cambers numbers are perfectly fine. On a sports car they is suppose to be neg camber, even more if you lower your car. My old M3 had over neg 3 degrees of camber in the back, talk about rails.
Hooman
Reply 0
Oct 7, 2005 | 06:20 AM
Quote: at least you got your toe fixed. I bet you were burning through tires. Your cambers numbers are perfectly fine. On a sports car they is suppose to be neg camber, even more if you lower your car. My old M3 had over neg 3 degrees of camber in the back, talk about rails.
Hooman
Yup... My first tire change was at 11,500 miles... for 2 rear tires.... now I am at 20K, my third set (first ever aftermarket wheels)
Reply 0
Oct 7, 2005 | 06:22 AM
Quote: Great choice on wheels!!! But of course I would be a bit bias, considering:
[IMG] [/IMG]
Hey!!!!! Awesome wheels man! We shall compare if BS or OB looks better with those wheels!!!
Reply 0
Oct 7, 2005 | 09:05 AM
Your camber is fine.. some SPC toe bolts and camber arms ($400) would fix you right up.
By the way, this is bad camber:
Reply 0
Oct 7, 2005 | 09:52 AM
Holy cow... that's like a 10 degree camber!!!!
Reply 0
