balance/alignment question
Old Oct 12, 2005 | 09:13 PM
Timskyline350gt's Avatar
I have a 03 coupe with Luff M1, 19x8.5 front, and 19x10.5 rear wheels. Using Hankook k104 245/35/19 front, and 275/30/19 rear.
Dropped it with Tein S-techs, 1.2"front, 0.9"rear.
How often should I balance the wheels under normal driving conditions?
How would I know if the wheels need balancing, what signs?
How would I know if the wheels are bent?
Old Oct 13, 2005 | 01:06 AM
Raznips's Avatar
never had a bent rim, but i believe there is a LOT of road noise and you can hear that something is wrong if its bent... someone correct me if im wrong
Old Oct 13, 2005 | 06:22 PM
rims
Well my problem is that the steering wheel shakes after passing 75 MPH. Before 75mph everything is cool. But at 75, the steering shakes. Its not a bad bad shake, but its one that for sure you would notice.
I have already gotten the front wheels replaced and balanced. Problem is still there.
What could it be?
I am running hankook 245/35/19 and 275/30/19 tires, and the car is lowered with Tein S-techs. But I don't think its a spring or tire problem since the shake doesn't happen at all speeds but only over 75MPH.
Old Dec 27, 2005 | 01:42 PM
rottenice's Avatar
The shimy shake
Assuming the balance was good, take it to either a good suspension shop or the dealer and have them check the outer tie rod ends. Further, there might be a defective ball joint elswhere in the system.
Most shops will charge little or nothing at all to do a front end check as this is how they make money. One other possible problem is the rotors. If the brakes are warped (happens, esp with hard use ), a vibration will result as described.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
