bronz TE37 19"
Old Jul 24, 2003 | 04:25 PM
fd3st04's Avatar
bronz TE37 19"
I have a set coming for my project car.
19x8.5
19x9.5
what size tires should i run?
245 in front and 285 in the rear?
anyone has those wheels alredy on there car?
03 G35 blk on blk 6 speed
94 rx-7 hks t04r
www.sportcarmotion./com
Old Jul 24, 2003 | 04:52 PM
Carlitos's Avatar
Re: bronz TE37 19"
235-35F & 275-35R
Carlos
6MT-DG/W-NAV
Old Jul 28, 2003 | 09:56 PM
tig488's Avatar
Re: bronz TE37 19"
i got 19-9.5" gunmetal TE37s, pics are here somewhere
2003.5 G35 Silver/Graphite 6MT Premium Coupe
Old Jul 29, 2003 | 01:18 PM
rajc007's Avatar
Re: bronz TE37 19"
If you have the coupe, it should be:
245/35-19 f
275/35-19 r
2003.5 CB Coupe 6MT
Pics
Old Jul 29, 2003 | 06:00 PM
wickedG35's Avatar
Re: bronz TE37 19"
make sure to post pics of your ride! My coupe is black and I too am thinking about Te-37's in bronze; would very much like to see how they look.
-Blk/Blk G35c
Old Jul 29, 2003 | 06:16 PM
tig488's Avatar
Re: bronz TE37 19"
i have pics of a black skyline (real skyline from japan) with bronze te37s, i cant remember where i got them, i think freshalloy, it looks pretty sweet, ill post when i get home if i remember.
Old Jul 29, 2003 | 07:15 PM
waijai's Avatar
i.love.gold
Re: bronz TE37 19"
I got the pic here.
Old Jul 29, 2003 | 07:46 PM
wickedG35's Avatar
Re: bronz TE37 19"
damn soooo nice.. do you have a side shot?
-Blk/Blk G35c
Old Jul 29, 2003 | 10:32 PM
Kozlikracing19's Avatar
Re: bronz TE37 19"
That looks fo da hook!
Nice ride man!
Old Jul 29, 2003 | 10:38 PM
tig488's Avatar
Re: bronz TE37 19"
no thats not it, i have 3 or 4 others of a different car, side shots and all, ill post when i get home.
Old Jul 30, 2003 | 08:47 PM
tig488's Avatar
Re: bronz TE37 19"
here it is
Old Aug 2, 2003 | 10:48 PM
hksjza70's Avatar
Re: bronz TE37 19"
where's that grille from? and is it available for the sedan?
Old Aug 4, 2003 | 02:36 PM
HateThatBobBarkr's Avatar
Re: bronz TE37 19"
i believe its gialla could be data system but i doubt it
if i had a black car id get bronze TE's im going for silver on my blue
-moooooo
Old Aug 13, 2003 | 11:16 AM
THEWB's Avatar
Re: bronz TE37 19"
yes the set up will be 245 35 19 fronts and 275 30 19 rear
keep in mind that a 285 30 19 will bubble over the rim because its a 19x9.5 if it was 19x10 or 10.5 then 285 will be fine
Old Aug 13, 2003 | 11:25 AM
THEWB's Avatar
Re: bronz TE37 19"
i also wanted to mention something
245/35/19 and 275/35/19 this set up is a no no reason being is the car is no longer factory when you change wheel to 19 or 20 here is what happens the tire in the rear ends up taller than the front this will creat THE STARSKY AND HUTCH look jacking your car up in the rear like a 67 mustang.... in order to keep the same diameter all around you need 245/35/19 and 275/30/19 now the tires are the same height all around ........running the other set up may influence handling because the front tire will spin faster than the rear you always want tires that spin at the same rate ......unless its a DRAG car where going straight is the object
