new 20 inch zenettis can i install my old sensors please help
Old Nov 9, 2005 | 12:03 AM
ebuy929's Avatar
hey
i just bought a new pair of 20 inch rims for my 04 coupe im getting them installed tomaro any chance of me using my tire pressure sensors from my 18s on them? and if i take out my sensors will i be stuck with that light on my speedometeor for low tire pressure
Old Nov 9, 2005 | 12:07 AM
Mike_Jones's Avatar
Originally Posted by ebuy929
hey
after you stick the sensors on in the same order (position) you shouldn't have any problems...
Old Nov 9, 2005 | 04:11 AM
G352NV's Avatar
Never enough
yes they will work.
Old Nov 9, 2005 | 06:24 AM
ebuy929's Avatar
my new rims require more psi they use 42 the stock sensors are set to 35 is there any way to change this?
or erprogram the sensor
Old Nov 9, 2005 | 07:38 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
They are fixed settings...
Why not fill with nitrogen?
Much more stable, less leakage, same PSI hot & cold.
Our local Costco is doing it for $0
Old Nov 9, 2005 | 08:15 AM
jnkirk1974's Avatar
Fastest G35 In Rockwall
I've always wanted to do the nitrogen thing in my tires, but the nearest place that does it for me is at Grubbs Infiniti. They are WAY far away from me.
Plus, I'd be afraid of what happened if you blew a tire. Would a mushroom cloud appear?
Old Nov 9, 2005 | 10:31 AM
kidtronix's Avatar
Optional
If you can get nitrogen inflation at Costco for free then do it!
Old Nov 9, 2005 | 06:37 PM
shipsaeki's Avatar
there is no set tire pressure for the psi sensors. Just what ever they are initialized at.
Old Nov 9, 2005 | 08:35 PM
ebuy929's Avatar
so if i install them at 42 then if i hit 39 the light will come on and how hard is it to put them on new not oem rims?
Old Nov 9, 2005 | 08:58 PM
MikeyMike's Avatar
Rollin On Dubz
Ebuy, got pics?
Old Nov 9, 2005 | 10:21 PM
ebuy929's Avatar
will on friday when i install them
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
stay_tuned
Jul 21, 2015 07:09 PM
Soumilg
Jul 18, 2015 12:33 PM
