Guys Please Help Fitment Question
Old Nov 17, 2005 | 07:03 PM
excel's Avatar
Just got my M45 Sport Rims 19x8.5 50mm offset. I put them on my G35 Coupe AT. They fit just right but to its capacity. Question is if i use a 5mm h&R spacer in the front will it be ok and clear.
Thank You in advance.
Old Nov 17, 2005 | 07:28 PM
Chico's Avatar
Why would you use a wheel that simply isn't made for your car? The offset is way too high, unsafe, not practical and the car probably looks odd. I would not even put those on a sedan that have an oem offset of +45.
I seriously doubt a 5mm spacer will clear your brakes Brembo or not. My best advise will be to get another set of wheels, but if you're really wanna risk it, take it to a shop where they can properly take measurements and then decide what size spacer you need to use.
Good Luck!
Old Nov 17, 2005 | 09:30 PM
excel's Avatar
What I meant was will it rub on any of the suspension pieces with a 5mm H&R spacer.I have put them on and they clear my non-bermbo breaks by about 3mm.
Thank You
Old Nov 17, 2005 | 09:35 PM
JDM 350GT's Avatar
...thats really tight...
and look at the offset...WOW!
how much you paide for a set of 4 (w/ w/o tires?)
just wondered cuz i would get something else than OEM rims heh just my 2cents
Old Nov 17, 2005 | 09:44 PM
excel's Avatar
4 w/o tires $590. So anyone please with any suggestion except to get other rims.
Thanks
Old Nov 17, 2005 | 09:45 PM
JDM 350GT's Avatar
...why is this so cheap?
is this forged or did you juet get a good deal? o_O?
how much lbs on each rim w/o tire?
Old Nov 17, 2005 | 09:48 PM
excel's Avatar
I believe they are forged, they are about 22lb. The deal was amazing thats why i jumped on them. JDM do you know if spacer would be ok?? in the front, im not really concerned with the back.
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
