difference between 215/55/17 and 225/55/17?
Old Dec 9, 2005 | 04:25 PM
mark5's Avatar
difference between 215/55/17 and 225/55/17? will i notice anything different?
Old Dec 9, 2005 | 04:44 PM
kenchan's Avatar
215 and 225 are the widths in mm.
55 is the aspect ratio, which is the % of the width of tire
118.25mm sidewall thickness (215)
123.75mm sidewall thickness (225)
that's only 5mm difference...you probably won't notice much other than
a more comfy ride on the 225/55's.
Old Dec 20, 2005 | 03:29 PM
t0pher's Avatar
10 mm width
and with a 55 aspect, you will be adding about 5 mm to your sidewall.
A better tire would be 235/50/17, which will add 20 mm to the width and hardly anything to the rolling circumference of the tire.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
doakley92
Sep 25, 2015 12:58 PM
twentyeggs
Sep 11, 2015 03:58 PM
