20" Wheels
Old Sep 2, 2002 | 07:28 PM
ncozby's Avatar
20" Wheels
I'd like to replace my factory 17" wheels on my G35 Sedan with either 19" or 20" wheels. Can you guys give me some input on the pros/cons as far as ride, handling, etc might be affected? I love the look of larger wheels but don't want to ruin the handling and integrity of my car. Also, can you even fit 20" wheels on this car without serious modification to the suspension?
Thanks!
Old Sep 2, 2002 | 08:06 PM
culmination's Avatar
Re: 20" Wheels
no modifications required in putting a 20" rims... i recommend 225/35-20 because the diameter of the tire will be similar to the original stock rim/tires. lower profile tires will give you better handling but your overall ride quality will suffer. rim/tires that weigh a lot will reduce performance in: acceleration, braking, fuel effiency. try to get aftermarket rims that are light.
Old Sep 5, 2002 | 02:34 AM
skeleton_cru's Avatar
Sedan
Re: 20" Wheels
Yeah, performance will be affected negatively. Also, watch out for pot holes, tires that low in profile will not protect your rims from damage.
Old Sep 9, 2002 | 07:08 PM
ncozby's Avatar
Re: 20" Wheels
Has anyone seen pictures of a G35 sedan on 20" wheels, or is anyone able to photoshop a G35 to make it look like 20"s?
Old Sep 10, 2002 | 05:12 PM
ryn8a's Avatar
Re: 20" Wheels
here:
https://g35driver.com/forums/showfla...sed&sb=5&part=
Old Sep 12, 2002 | 07:05 PM
Sedan
Re: 20" Wheels
Just click my link and go to my Yahoo briefcase. Check out the G35's in LV.
Old Aug 13, 2003 | 11:10 AM
THEWB's Avatar
Re: 20" Wheels
here is a reply to your question yes you can put 20's all day long DO NOT PUT 225/35/20 like someone suggested keep in mind that 225mm wide with a 35% side wall is too too close to the ground the set up i have done is 245 35 20
and 275 or 285 30 20 in the rear here is a picture if you would like to run the same width all around then you can go 245/35/20 or even 255/35/20 all around the silver car runs these the black one runs the stagered set up ..
Old Aug 17, 2003 | 10:07 PM
Edretti's Avatar
Re: 20" Wheels
Granted I have a coupe with 20's but I have the same staggered set up as well and it's awesome! Everyone that looks at my car thinks I have 19's on and not 20's. 245/35 in front and 285/30 in the rear! Yes very fat!
Edretti
2003 Infiniti G35 Coupe 6mt Loaded Brillant Silver
http://www.cardomain.com/id/edretti
Old Aug 18, 2003 | 08:20 PM
gaklid's Avatar
Re: 20" Wheels
Everybody says my 20's look like 18's or 19's too. The wheel wells are so big on these cars, they just swallow 'em up!
Ivory Pearl/Premium/Xenon/
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
