NEW MEMBER 19" or 20" wheels
Old Feb 5, 2006 | 11:45 PM
mannyh316's Avatar
]I AM GOING TO PURCHASE WHEELS NEXT WEEK SHOULD I GO WITH 19 or 20
AND TYPE OF TIRES DO YOU GUYS RECCOMEND I WAS THINKING NITTO's
Old Feb 5, 2006 | 11:53 PM
Jee_35's Avatar
Hey, welcome to the boards. The people here are great, and there is help with just about every topic you need covered. If you are in the market for wheels/tires, why don't you look up Volk Racings? I have the SF Challenges in 19x8.5 F and 19x10.5 R with Toyo T1R's. Here's a few pics for ya.
Old Feb 5, 2006 | 11:59 PM
truplay8's Avatar
THE BATMOBILE
go with 20's if you have the money...........i also suggest toyo t1r's.........use the search function
Old Feb 6, 2006 | 12:04 AM
mannyh316's Avatar
tire size???
Old Feb 6, 2006 | 12:56 AM
Riche12ich's Avatar
20"s for sure.
20x8.5 or 20x9 fronts with 245/35/20
20x10.5 rears with 275/30/20
Old Feb 6, 2006 | 01:21 AM
speedraver's Avatar
wassupMyNinjas! (^_^)
If you don't plan on taking it to the track, I say go for 20's if you've got the cash... if you go for 19's, make sure you get a large rear lip & drop it!
Here's 19's (stock) vs 20's HRE 540R's (20x9 front & 20x10.5 rears) on Falken ST-115
Good luck!
Old Feb 6, 2006 | 01:25 AM
GsUpHoesDown's Avatar
20s of course.
Old Feb 6, 2006 | 03:32 AM
mrjonang's Avatar
if you can spare the cash, go with the 20".
Old Feb 6, 2006 | 11:31 AM
Nodnarb901's Avatar
I am rolling on 20's with no regrets. The tires were cheaper than the 19's.
If you look at the link:
http://cgi.ebay.com/ebaymotors/19-WH...35382479QQrdZ1
The G35 at the bottom of the pic is mine.
Old Feb 6, 2006 | 11:39 PM
mannyh316's Avatar
thanks, nicw HREs I WILL GO WITH 20 I WILL POST PIC
Old Feb 7, 2006 | 06:29 AM
skeleton_cru's Avatar
Sedan
You don't have to use all caps when you post.
Old Feb 7, 2006 | 07:31 PM
haze's Avatar
Originally Posted by Riche12ich
20"s for sure.
I'm wondering why do many forum members suggest 275 rear tires on 10.5" rims rather than 285. I'm asking this because after some calculation, 285/30 actually retains the overall diameter on the rears better.
Old Feb 7, 2006 | 07:42 PM
BrianlG35C's Avatar
Ohio G Club Member
I don't, I suggest 285s.
Old Feb 7, 2006 | 08:09 PM
GThIrtYFiZle's Avatar
Would the 285's in the rear rub at all on 20x10's. I just bought 20" rims too and contemplaiting wether to buy 275 or 285's for the rear, only concern is the rubbing and by the way I have an 06 coupe.
Old Feb 12, 2006 | 03:49 PM
Nuggle's Avatar
Recommended for the toyo T1R
245/35ZR20 8.0-8.5-9.5" - 776 RPM this set up your off by -20 RPM
275/30ZR20 9.0-9.5-10.0" - 782 RPM this set up your off by +4 RPM
255/35ZR20 8.5-9.0-10.0" - 769 RPM this set up your off by - 27 RPM
285/30ZR20 9.5-10.0-10.5"- 776 RPM this set up your off buy -2 RPM
The front tire rpm will be off too much from stock you will notice a diffrence
Combo
245/30ZR20 8.0-8.5-9.0" - 801 RPM this set up your off by +5 RPM
would be nice too but i am not sure if 245 and 285 will work properly
but the best set up would be
On a 05 6MT or 06 model stock is
225/40ZR19 7.5-8.8-9.0" 796 Rotations per mile
245/40ZR19 8.0-9.0-9.5" 778 Rotations per mile
FYI the middle number is the suggested rim diameter
