rim to brake distance
Old Feb 8, 2006 | 07:57 PM
Fiveseven's Avatar
hey guys, i just picked up some 20" iforged evolutions about 2 months ago... and the rims sit really close to the brakes... too close for comfort.. the front rim is probably 2-3 milimeters away from the brake caliper but the rear is probaby 1/2 - 1 milimeter away from the brake caliper... any chance that the rim spoke would actually hit the brake caliper? am i worrying for nothing? i asked this on another forum but got little to no help.. :P any thoughts? also any idea what my tire pressure should be at? <20x8.6 20x10 iforged evolutions>
Old Feb 8, 2006 | 10:06 PM
My350GT's Avatar
I had the same problem with my Stillen Racing brake calipers which would actually just touch the caliper. I took care of this problem by putting a 1/8" spacer between the hub and wheel. It should bring it to a little over 2mm.
Old Feb 9, 2006 | 05:07 PM
Fiveseven's Avatar
if i do that my wheels would stick out too much and hit my fenders.. i already have my fenders rolled... i wouldnt want it to hit again.. i guess my main question is.. will the brake caliper ever hit the spoke on the rim?
Old Feb 9, 2006 | 07:15 PM
boro240's Avatar
Unless you think the calipers would be moving outward (if this is happening you have much worse things to worry about!), then no it's not a big deal. If it clears it clears.
Old Feb 9, 2006 | 10:50 PM
Fiveseven's Avatar
thanks boro :]
Old Feb 9, 2006 | 11:16 PM
GThIrtYFiZle's Avatar
What size tires do you have????
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
mushu
Jul 15, 2015 03:55 PM
