rubbing noises... come on guy's someones gotta have an idea
Old Mar 21, 2006 | 03:38 AM
WYSIWYG's Avatar
Okay, let me try one more time...
anyone with experience or solutions to rubbing issues with aftermarket rims. running 255/285 30 20's. I found out that the rubbing is coming not from the fenders but from the plastic linings of the wheel well. For some reason, the right side has a plastic bump bigger than the right, but i get some rubbing on both fronts.
I'm completely stock '06 coupe w/ sports suspension. I don't think rolling the fenders will do any good as it is not that part that is rubbing. Can't lower the car as this will be made worse. I didn't know the sport suspension on the 06's compressed so much. The 05 seemed much stiffer. I've got about a little less than 2 fingers from tire to fender.
Any ideas or suggestions on how to solve the problem (other than ripping out the plastic lining)?
Old Apr 21, 2006 | 02:57 AM
accordfreak's Avatar
WYSIWYG did you fix your problem yet?
i just found this thread.. so i'm wondering also because I might be going with the same setup.
also does the TPS fit into your DPE's? you have Alnk52's DPE's now right?
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
jjohns2711
Aug 5, 2015 08:58 AM
