Will it fit?
Old Mar 25, 2006 | 12:22 PM
subrobo's Avatar
Will it fit?
Car: 2003 G35 Sedan Stock Sport suspension, running on stock 17'' now
New Wheel size: 19x8.5 38+ 114.3 all around
New Tire: Will 235/35/19 be safe to put on? i did a tire wheel calculation and its about 3.2% in diameter different. Please help
Old Mar 25, 2006 | 12:53 PM
ttrank's Avatar
Grocery getter
You should be fine but I would run a 245 to fit the rim better.
I have H&R springs (1.2f, 1.0r) with 20x8.5's +20 and 245/35's with no problems.
Old Mar 27, 2006 | 05:50 AM
skeleton_cru's Avatar
Sedan
Perfect set-up on the wheels in my opinion, but you should consider 245/40/19 for the tire size. That will be closer to stock tire height.
Old Mar 27, 2006 | 05:51 AM
Sedan
I think you should double check your offset; +20 would be sticking way out of the fender.
Old Mar 27, 2006 | 09:24 AM
KrazyEd's Avatar
Wheels are fine. But I would run 245/40/19 for your tires.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
dseet
Oct 11, 2015 12:40 AM
Claudiu
Sep 26, 2015 01:04 PM
