Taking off Hub Centric Ring?
Old Apr 22, 2006 | 11:26 PM
HGS_G's Avatar
I would try a narrow width chisel, the type that carpenters use for wood working and a hammer and chisel a around the circumference of the rings a little at a time. Did you track your car often cause if not, they must be some cheap hub rings made out of the cheap softer plastic for them to melt around the hubs like that. If you track your car, you should really use aluminum hub rings with some anti-sieze.
obender66
18 Inch
Mar 13, 2016 12:20 PM
Gookiecrunch
Aug 19, 2015 12:00 PM
papo020
Jul 17, 2015 10:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
