Help G35ers! My Michelin 245 has a nail!
Old Sep 12, 2003 | 11:45 PM
Drewer's Avatar
AHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!
It's a really slow leak, so the damn nail is acting as a plug. My tires only have about 15k on 'em! I don't want to buy a new set of rears yet. . .and I sure as hizell don't want to buy a complete new set. Has anyone used any of those "fix flat" instant tire fixers or anything similar with good results? Does anyone have any personal recommendations? I am SOOOOOOOOOOO bummed!
Thx!
-drew-
p.s. I'm loosing about 5 psi per day.
Old Sep 13, 2003 | 12:05 AM
RashMan1450's Avatar
Re: Help G35ers! My Michelin 245 has a nail!
THere is nothing to be bumbed about. Where is the nail in the tire? If it is on the same side as the RIM, you need to get a new tire. If it on the bottom, where the tread is, take it to a 76 gas station and get it pluged. Tell them you have a flat tire and they will take off the wheel, take the nail out, and plug it with tire plug. IT will cost all of 10 dollars to fix. BUT only if its on the same side as the tire tread.
Good luck
2004 Diamond Graphite G35 Coupe 6MT, Premium Package, Aero Package, DVD Nav
Old Sep 13, 2003 | 12:28 PM
Premier's Avatar
If it's on the tread, then you're ok........but use the fix-a-flats only if it's an emergency because they've been known to discolor aluminum wheels.
Wherever you take your rims, make sure they use thin wall sockets to remove your rim........otherwise, they could easily scratch up your lug holes.
Old Sep 13, 2003 | 02:18 PM
micnic's Avatar
Unless it is in the side wall, you can get it patched. I definitely would not get it plugged. Plugs will eventually leak again. Patches are the way to go. Take it to a respected tire dealership and it should only cost $10-15.
Old Sep 13, 2003 | 06:11 PM
RacerX's Avatar
Yeah, definately you should never plug a tire unless it's an emergency roadside repair. A proper flat repair involves taking the tire off the rim, patching from the inside, then rebalancing. But get this done as soon as possible, as having a nail in your tire for a prolonged period can destroy it, especially if it's a long nail.
04 G35 6MTS Aero Kit/Nav/Prem/Wint (Hopefully Sept 03)
Warning: Objects in Mirror Are Losing!
Old Sep 14, 2003 | 12:05 AM
Jedi's Avatar
Just like the stock lug wrench in the trunk scratches the openings!!!! DOH!
"Use the Forced Induction Luke!"
-Jedi
2003 G35C, 6MT, Navi, Black Obsidian/Graphite
Old Sep 14, 2003 | 01:00 PM
lowrider's Avatar
If you live in an area with a Discount Tire Store, they will patch your tire for Zero $. As suggested above, whatever you do "DO NOT PLUG YOUR LEAK" "PATCH IT, FROM THE INSIDE" but, only if the hole is in the tread area. Good Luck.
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
gqraverice
20 Inch
Sep 29, 2015 05:39 PM
TNRocker
Sep 21, 2015 08:36 AM
Footballmania32
19 Inch
Aug 13, 2015 03:07 PM
