Will 285/30/19 work on the back
Old Sep 13, 2003 | 03:41 PM
G35Blake's Avatar
Will 285/30/19 work on the back. Ilooked at the BC wheels at discount tire and they told me to put 19X10 w/ 285/30/19 Falken Beta 451.
Old Sep 13, 2003 | 08:19 PM
RaySur350GT's Avatar
Re: Will 285/30/19 work on the back
Yes they fit but you will have incorrect readings on your Speedometer and the VDC will be off.
It's not worth it, try and go with either 275/35/19 or 285/35/19. Both of those will fit on a 19x10 rims fine
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Old Sep 13, 2003 | 09:00 PM
lowrider's Avatar
I second RaySur350GT. Those are the right size for the back. In the Front you'll want 240/35/19s on 19X8s
Lou
Old Sep 14, 2003 | 02:31 AM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
285-30-19 will work fine. I have the Same size Dunlops on my Volk 19x9.5 I don't have any Problems with Speedo Or VDC. For Front Either 235-35-19 or 245-35-19 will work
PS. Lowrider Who makes a 240-35-19 ??!!
NismoCPV-35
Old Sep 14, 2003 | 02:50 PM
JPJ's Avatar
JPJ
I just placed an order from DT for BC Forged wheels and Falken tires. I'll be running 19x10s in the back w/285/35/19s and 19x8s up front w/245/35/19s.
2003.5 G35 Coupe 6MT
CB/Graphite/Prem/Aero
Clear Corners/Tint
Alum Pedals
Zaino!
Old Sep 14, 2003 | 06:47 PM
lowrider's Avatar
To name a couple - Bridgestone SO3, Michelin Pilot Sports, Dunlop SP Sport 9000, Yokohama AVS Sport, and etc. 285/30/19 in the back is about 1" to small in OD. It kills the stager, leaving the stock front (and in your scenario, which does have the right size front) the same OD as your modified rears. Not the right thing to do.
Lou
Old Sep 14, 2003 | 10:02 PM
NismoV35's Avatar
Really They all Make A TIRE SIZE 240-35-19??!! I Checked and Rechecked. Sizes run from 235 then Jump to 245....... Still ROLLIN on my 285 30 19 Dunlop SP 9000.........
NismoCPV-35
Old Sep 15, 2003 | 08:09 AM
lowrider's Avatar
OK - OK - I ment 245/35/19 - sorry for the wrong info.
Lou
Old Sep 15, 2003 | 06:55 PM
NismoV35's Avatar
I Knew that you Typed in the Wrong Number. I went 285 30 19 Because the Price was right, $ 226 & I was Waiting for a 19x10.5 wheel. I'll have to get new tires Every year any way......
NismoCPV-35
Old Sep 15, 2003 | 08:07 PM
lowrider's Avatar
OK, you made me squirm. When you retire (no pun intended) get the 275 or 285/35s. You'll find they will work better, and fill up the well better also.
Lou
Old Sep 15, 2003 | 11:27 PM
G35Blake's Avatar
When do you expect to put them on?
When you get them let me see I am anxious to see the BC wheels on a G coupe.
By the way which BC wheels are you lookin at.
Old Sep 17, 2003 | 03:59 PM
bzabodyn's Avatar
I'm almost positive that a 285/30 and a 275/35 on a 10" rim are nearly identical in O.D. - don't quote me on that, but that was my impression...(285 would look better though - wider tread)
Old Sep 17, 2003 | 07:59 PM
lowrider's Avatar
285/30/19 = 25.7" OD (SO3)
275/35/19 = 26.6" OD (SO3)
Almost an inch different.
Lou
Old Sep 18, 2003 | 07:20 PM
bzabodyn's Avatar
but when you look at those O.D.'s it clearly shows that the 275 is on a 9.5" rim and the 285 is on a 10" rim - stretching the 275 on the 10" rim causes the sidewall height to be decreased slightly...
sofa king
19 Inch
Aug 9, 2015 04:10 PM
apintojr
Jul 23, 2015 10:52 AM
Lsantana757
Jul 20, 2015 09:08 AM
Jadenkid22
Jul 14, 2015 12:33 AM
