DIY: PAC Steering Wheel Controls (W/ Pics)
#31
#33
Not quite sure what is going on but I tried to reprogram everything once again. Checked all wires and resistors are all good. Now after reprograming everything works fine again. But then after turning car off and then back on the steering wheel function doesnt work correctly. After another reprogram, now the volume up and down both control volume up only. Same goes for seek up and down, when either is used it just seek up function.
Could it happen to be that the black wire from the pac unit need to be connected to constant -12V wire or does it just need to be connected to chasis ground. I saw a few write ups that said it must be connected to constant -12V. My yellow wire is connected to chasis ground. I also just connected resistors right into the pins and did not go the solder route, could this be why the unit is acting up? Any help is appreciated. Thanks.
#34
The chassis ground is constant ground. It's always hooked to the battery.
Can you show a pic of your "shove resistors into pins" method? It sounds like that's definitely what you did wrong, it's loose and not giving a consistent enough voltage for the PAC SWI to interpret the effective resistance of the circuit.
Your wires should look like this - SOLDERED:
And then those wires can be soldered or clipped into the old harness like so (the clips in the background:
#35
Yea, looks like I will have to redo mine where the resistors connect to the car harness. Probably loose connection there. I had the yellow wire grounded to a bolt and the black wire connected to the black wire from the radio wiring harness.
#36
Im seriously stumped and frustrated...
I have a 2005 g35 coupe a Pac swi-x and a avic920bt
I was able to wire everything up as per
http://www.pac-audio.com/swixprogram...ehicles&ID=211
I can also get it into program mode 3, but when it comes to programming the controls in order...its just not working. I hit the program button then the volume up button.The program led goes out once I let go then I hit program again for the next button volume down. I continue this until Im done with the last button. I dont get the 7sec confirmation light or any function out of the steering wheel controls..If anyone has done this successfully, can you tell me what I am doing wrong? PLEASE HELP!
#37
Did you ground the yellow wire from the factory harness?
Have you watched my video of me programming the PAC SWI-PS? It's in my double din shopping/resource list.
According toyour link, the SWI-X programs the exact same you only push the program button when you want to skip a function, not after pressing the button associated with that function.
#38
Ground the yellow wire?
I only grounded the yellow wire from the pac controller not from the g35 harness, Could this be it? In the pac website directions it says you dont need it, but I was look on https://g35driver.com/forums/audio-v...-pac-steering-
wheel-controls-w-pics.html
and it said to do this. Is this correct?? Im grounding this wire today if this is what I need to do? Where is your video located at?youtube?Thanks for the help and quick response,,,your awesome people!
PS the pioneer 920bt knew I bypassed the emergency break sensor to ground lol...so it gives me two pop ups when starting my car.
#39
The PAC controller's yellow wire doesn't get grounded. The one from the factory harness does. It *must* be grounded in order for the car to have a reference ground. If you'd called PAC's support number they'd probably be able to tell you this in about 45 seconds after calling... Ask me how I know
Yeah, it's hosted on youtube, if you look at the top of this forum, there's a sticky with my name all over it, inside the resource section is a video of me programming the unit.
If you look on AVIC411.com, you'll find the way to properly allow passengers to adjust settings on the radio while in motion without warnings.
#40
Hi Wrathernaut,
Thanks for the video of the programming! I ended up getting the AVIC 120BT instead of the kenwoord DNX9960 I originally had planned.
Wifey loves it =]
We just need to learn how to speak proper english I guess. Any advice about how to use the navigation? It doesn't seem as intuitive as I thought it would be. Is there a way you can find alternate routes?
Thanks again for the vid!
Wifey loves it =]
#42
#44
Is there any advantage to using the PAC SWC over the Metra AXXESS ASWC...? It seems like a lot of effort to get the PAC steering wheel control to work. With the Metra AXXESS ASWC I simply connected the wires to the G35's steering wheel control harness, programmed the SWC unit, and all worked fine.
Just curious / just asking...
Thanks -- Cameron
Thanks -- Cameron
