f90bt vs f900bt
Old Sep 22, 2009 | 11:43 PM
highstakeG's Avatar
f90bt vs f900bt
i curently have the f900bt and to be honest the sound quality sounds like ****. its really quite and the ipod has no sound at all. so i was wondering if the f90bt will work better? and if it takes the same harnesses so i can just plug it right it to where the f900bt was.
Old Sep 23, 2009 | 08:57 AM
bina12834's Avatar
sounds like you have a wiring problem somewhere....i wouldnt blame the f900 quite yet.
Old Sep 23, 2009 | 09:10 AM
highstakeG's Avatar
i have done some research on this and im not the only one who had this problem. everyone else that had it got rid of their f900bt most replaced it with a f90bt.
Old Sep 23, 2009 | 09:21 AM
TroysG's Avatar
what wiring harness do you have?
Old Sep 23, 2009 | 12:09 PM
highstakeG's Avatar
im pretty sure its the 7551
Old Sep 24, 2009 | 12:07 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
If there's no sound from the iPod, check that you have both the RCA cables and the USB cables connected to the pioneer iPod cable. It does not send audio over the USB connection, the USB connection just controls the iPod. The audio is sent via the two red/white RCA cables as AUX1 - make sure that AUX1 is set to iPod, so that when iPod is active, it listens to those cables, otherwise the sound will come through when you choose AUX1 as the input, not the iPod.
Old Sep 24, 2009 | 09:47 AM
TroysG's Avatar
the 7551 is junk whoever thought it was a good idea is retarded...
use the 7550 and you'll notice an immediate improvement
Old Sep 24, 2009 | 10:51 AM
highstakeG's Avatar
how much harder is that one to install if its differant at all? beacause the 7551 confused me haha
Old Sep 24, 2009 | 10:55 AM
highstakeG's Avatar
and also is this the correct one?
http://cgi.ebay.com/NISSAN-95-07-HARNESS-METRA-70-7550_W0QQitemZ170265550767QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item27a49e1faf&_trksid=p3286.m20.l1116
Old Sep 24, 2009 | 11:01 AM
MJION's Avatar
I installed the F90BT and used the 7551, I am pretty sure it was required since it is 4 ohms system?
The system sounds really great however on certain artists when playing the ipod I can max the volume out at level 62, I am wondering if this is because I need to upgrade my stock bose speakers or is it due to the harness...?
I like my music LOUD.... like I said it does not happen all the time, but occasionally..
I do have a aftermarket sub and amp, but I also plan on upgrading the front door speakers...
hopefully this will help......?
Old Sep 24, 2009 | 11:02 AM
MJION's Avatar
HighstakeG- You have to turn the Aux input to ipod otherwise it will not recognize it.. I believe this is in the setup options...
Old Sep 24, 2009 | 02:45 PM
TroysG's Avatar
highstakesG: that is the harness. and it's no harder than connecting the wires to the corresponding colours on the aftermarket deck and you DO NOT use the deck's preouts.
What many people have failed to notice is that with the earlier Gs they don't have BOSE speakers, just the amp. meaning it's just a regular amp. the speakers are nissan's clarion. I stopped installing in 2006 and every G I took apart up to an early 06 model and it had clarion speakers but had the Bose logo.
Old Sep 24, 2009 | 02:55 PM
MJION's Avatar
TroysG- LMAO
By the way I was hoping you would have an answer to my previous question....
Old Sep 24, 2009 | 03:55 PM
bina12834's Avatar
its the crappy pioneer ipod cable that comes with the f90bt. i had the same problem, bought a Belkin AV ipod cable from Best Buy to replace the pioneer ipod cable and everything is golden now. i like my music loud and volume level 40 is blasting when i have my windows down on the highway when playing my ipod.
Old Sep 24, 2009 | 04:28 PM
MJION's Avatar
Thanks Bina! how the hell did you figure that one out... lol
I will have to invest in that upgrade, however I am not looking forward to taking the dash apart in order to do so...
Does the volume level on the ipod when you plug it in have anything to do with it?
On another note....
Have you DL'd the 3.0 update? If so is it worth it?
how do you like the F90BT?
Yeah it has a few issues, I am sure both you and I know what they are..
But personally I could not be happier for the money I spent...
