does 03 coupe have stock sub?
I have my interior gutted and i don't see a sub. Rear deck has 2 6x9 is the sub in the trunk on the left side of the spare?
Im also having trouble figuring out where to put a sub. My options are 1 small 8 in sub in 6x9 location , not into that one to much
2 ..2 8 inch subs in rear 6.5 in woofer locations. This im leaning towards but it might rattle to much
3 next to spare on the left where i believe the amp is but idk if the sub is there.
Or 4 sacrifice trunk space that i need for tools and make a stealth box
There is no sub in the coupe version, just the midrange 6x9's on the deck. I think you can get 12's on the left and right side of the spare tire but you will lose a lot of space and will need to fabricate a hatch for access to the tire, I had 2 tens in the rear at one time with one of those prefab boxes but sold them for a 12. Got rid of that and now going to put 2 dynomax 12's on a IB behind the rear seat. Just got the subs in today and will start ripping everything out this week so I can figure out how and where the mount points of the board will be.
You may be able to put a 8" in the rear side panels but you are going for 8's you can mount them on the rear deck or on a baffle board behind the seats like what I am doing, plus it is a hell lot easier. You can make an adapter based on the 6x9's that are already installed or take them to a shop along with your woofer and have them make one for you. A 6x9 has roughly the same surface area as an 8 so if you go that route you won't take a hit on sound from the adapter. The main issue would be clearance for the mechanical xmax. You may need to reinforce the rear deck, but that is mainly dependant on what type of sub you get for it. You should also check clearance to see that may be a problem.
Il measure and see if i can get 1 10 next to the spare on driver side . With a good grill and fiberglass reinforcement that would work.
Post pics of ur build im curious to see how it comes out.
Yea maybe il use your idea if i cant get anything next to spare. An 8 would be good on the deck but i have a feeling its gonna rattle to much.
The problem is these subs use tall boy surrounds and that is making things interesting. There seems to be just enough room for xmax (+/- 5-10mm) if the subs are inline with or near inline with the sheet metal. That in itself is not a problem, I am using 3/4 MDF so I can rabbit the sub opening down to around 3/8's so the subs sit in the baffle plus add support on the backside. I am not to sure if there will be enough clearance for the frame gasket and support it at the same time plus enough clearance for the motor assembly in the trunk area.
Once I get a template made tomorrow, I will have a better feel for what I will be able to do. I just now have enough time to do this, so hopefully it will be done before the weekend. My intake manifold will be here Friday so I want to get that installed as well.
fchdx
05-12-2016 05:19 AM
Genthusiast35
Steering & Suspension
03-14-2016 03:17 PM
