Metra Axxess Programming Issue
Hey guys
I could never get the Metra Axxess Steering Wheel Control Module to work in my G35 sedan non-Bose. I made sure all the wiring was right per Wrathernauts double din installtion thread. I installed the Pioneer 4100nex.
Anyways when i turn on the car and hold the volume up it doesnt program as stated by the Metra Axxess instruction manual. It first flashed rapidly. Then when I hol the volume up, it starts blinking red and green on and off. And it doesnt stop even if I let go of the button.
So far I have been unlucky getting this thing to program.
Here is a video:
Here is a video:
Looked like you were holding "Volume Down" there. You end up holding vol up for almost a minute for it to program. Beyond that, the usual problem is that the yellow wire from the M39 harness isn't properly grounded, with a less common problem being that you had factory bluetooth and didn't unplug and bypass the factory bluetooth adapter.
Homamk
12-31-2016 07:39 PM
MilesToInfiniti
03-05-2016 11:27 AM
sumptimwong
03-04-2016 04:58 PM
