Dash Camera Install Help
Old 03-19-2017, 12:21 AM
g35Hawk's Avatar
I recently purchased a Blackvue DR650S-2CH dash camera and power magic pro. I have already installed both cameras and the are working great. Im having trouble figuring out which fuses to tap into for the power magic pro. There are 2 cables that need to go to fuses There is a yellow cable is labeled BATT(+) which needs to go to a constant power fuse slot and a red cable that is labeled ACC(+) which needs to go to a switched fuse slot. I do not have the proper tools nor knowledge to figure out which fuse does what, so any help would be greatly appreciated.
Old 03-19-2017, 09:03 PM
Urbanengineer's Avatar
Received 1,018 Likes on 936 Posts
The yellow runs all the time I believe, so your mileage may vary.
I would only tap into switched power.
Consider an "add a fuse."
